Intermitting drying fault.
Drying three loads, first two loads dried as normal, the third load did not dry. Vent pipe blowing cold, checked the heating element, removed it from the dryer, first connected the heater directly excluding the thermal switches worked fine, checked the thermal switches continuity on both switches, Reconnected the wiring as was. Vent blowing hot.
Any ideas?
Any ideas?
