Shelly 1pm enclosure
14 Nov 2006
Manchester
I'm trying to find a suitable enclosure to stick a Shelly 1pm Mini in to the ceiling. The dimensions of the shelly is 29x34x16 which suggests it should fit in a normal wagobox/connexbox but it might be a tight squeeze? I've looked at the quickfix JB u as well which I've seen mentioned elsewhere, as it looks to be designed to fit but getting hold of one locally seems to be a struggle.
Has anyone used either to enclose a shelly? I saw another post there they used a much larger box but up in the loft space where it would be relatively easy to get to in the event I had to replace or bypass the shelly but in the living room it seems a bit excessive?
Thanks!
Wiska box or you could just fit a single plasterboard back box and a cover plate if you want to get at it again
I did think about that one briefly but the WAF was already low because I've got to cut in to the ceiling to get at the wires (why are they always just slightly too short?)
