- Joined
- 17 Nov 2025
- Messages
- 7
- Reaction score
- 2
- Country
I’m a DIYer fitting a new bathroom (adding a bath where there hasn’t been one before) and need a sanity check on my structural plan. The structural engineer has advised "Upgrade to minimum 150mm depth at 400mm centres".
Existing Joists: 120mm x 45mm (5x2) at 400mm centres.
End A (Masonry Wall): The current joists are pocketed into an internal masonry wall.
End B (Steel Beam): The joists are notched to sit on the bottom flange of a steel beam. The bathtub will sit on this end of the room above.
Access: Ceiling is down, bathroom above is empty.
Constraints:
My plan:
I plan to sister new 150mm x 50mm C24 timbers alongside the existing ones, connecting them with noggins and bolts through the noggins.
Method:
Wall End (Hanging):
I’ll use Simpson JHM Masonry Hangers face-fixed to the brickwork with chemical resin and bolts
Steel End (Bearing):
I’ll notch the new 150mm joist to sit directly on the steel bottom flange.
Connecting the noggins and joists:
Because of the 50mm gap, I will use solid timber blocking (noggins) between the old and new joists.
I’ll use M12 threaded bars with 50mm square plate washers bolted through the blockers every 600mm along the span to prevent buckling/twisting.
The images are my sketches of what this will look like on each side, one against the wall, the other against the steel beam.
Please let me know your thoughts!
Constraints:
- I do not want to disturb the existing brick pockets as they are shared with the joists in the next room. I assume that face fix hangers are the best option here (unless you recommend otherwise?)
- Using a masonry hanger at the wall end forces the new joist to sit approx 50mm away from the existing joist (due to the hanger flanges) so they can’t be glued and bolted flush.
My plan:
Method:
Wall End (Hanging):
