Bath mixer tap handle will not budge
28 Oct 2008
Hampshire
Hi guys,
I’ve got a pair of fairly basic bath mixer taps. The hot tap has developed a slow but constant drip, so I was planning to change the tap gland/washer rather than replace the taps completely.
I’ve removed the centre screw from the hot tap handle, but the handle itself will not move at all. I’ve tried WD-40, firm hand pressure, controlled brute force, and even a gentle tap with a hammer — it will not budge in the slightest.
Before I go any further, are there certain mixer tap handles that are non-removable or fixed onto the spindle? Or is this likely just seized solid?
I’m trying to avoid changing the whole tap set as access is very tight and the bath panel is fully sealed in, so replacement would turn into a much bigger job.
Any advice appreciated.
Pop the red cap and find screw inside or Allen key/screw around the back through hole.
Those taps will be a quarter turn ceramic so you will have to order the correct one online.
Unlikely to find one local as so many sorts.
Masking tape around handle, then with a wooden hammer, smack it off when you have removed screw
Hi wayners thank you for the reply, I have already removed the red cap and the screw and still will not budge, I have looked on the back and there is no sign of another screw/allen bolt ‍♂️
You don't have any options..
You need to escalate. Basically. Start off sensible and tap it a few times. If that don't work start swinging.
If that don't work start swinging and follow through
Will give it another go
Dribble some lemon juice/kettle descaler/citric acid, down the hole you remove the screw from - likely it is just an accumulation of limescale, which it jamming the top of the tap handle in place. The acid, will dissolve the limescale.
Once you get the cartridge out, it is also worth soaking it in limescale too - it might cure the drip, and avoid you needing to buy a replacement.
