It does have an impressive lumen per watt, and looks as if it lights in nearly all directions, but
as one looks at the pictures it has the same problem as many LED bulbs, it does not put out any light towards the base. They do make a clear version Seems to be just a tad overpriced.
I have both the first eBay link and fillament ones and can confirm they DO put light out towards the base. And will light a ceiling just like an incandescent. That why they are marked 330 deg
Buy the eBay one then. Cheap and good light output all directions
