Extension flat roof leak help
ih
4 Nov 2006
London
Hi
Water leak noticed in kitchen wall pencil thin line ( photo) on checking on flat roof suspect area marked green in the photo that area is SOFT to touch indicating
Water ingress?? I need help advise to fix this to reduce bickering lol other tapped area are not related they were put to secure joints etc thanking
In advance
Regards
Iqbal
Hi
In advance
Regards
Iqbal
Your roof has had its day, but I'm guessing you already know that. If you do strip and re-cover, be aware of insulation obligations.
  • Thanks
Reactions: ih
Noted obligations apology did not know that it had its day it is 10/12 years old being OAP memory playing trick on the time
It's been poorly patched .. as above budget for re roof
It will have to wait until summer to get favourable weather any thoughts on detailed material guidance? As Google has various suggestions
But prefer from the more experienced & knowledgeable this will also help to finalise with the qualified roofing company thanking in advance
