ICOS24 condensate trap plastic nut corroded
31 May 2020
UK
Noticed my ICOS24 boiler was dripping from the rear right area of the lower plate a few days ago. Isolated the power and called British Gas in to take a look.
The engineer found the issue, a corroded plastic nut that holds the condensate drain rubber hose to the S-trap.
I was amazed as to why this had corroded, i thought the whole idea of the S-trap componets being plastic/rubber was to avoid corrosion caused by the acidic nature of the condensation. BG engineer said he had not seen this before and couldnt explain it.
He fitted a new trap and rubber hose, the old S-trap was quite gunked up with small black metal parts (apparantly)
Any ideas?
+1, that's not really corrosion. The large number of heat cycles and the amount of time that it has been in service, then the plastic has slowly broken down. It is rare but I have seen it a couple of times before.
It's almost like the same process that PP/PB goes through when outside and UV breaks it down over a long time, it seems to end up in the same brittle/powdery way.
