- Joined
- 29 Dec 2025
- Messages
- 460
- Reaction score
- 28
- Country
Where, please highlight the exact passage that supports your claim, and include a link to your source.as per the law I posted.
No need - read it for yourself
Using a weapon, such as a scaffold bar, is not reasonable force to try to arrest someone.Nothing requires you to stop attempting to apprehend a criminal, just because they are no longer in the act of committing an indictable offence. Your right to use reasonable force continues while they remain at large.
I did ask you to highlight the exact passage to support your interpreatation of the law.Where, please highlight the exact passage that supports your claim, and include a link to your source.
Nonsense, dummy.Wrong law
Can you copy and paste the section that you claim supports the right to use unreasonable force, e.g. such as a scaffold pole?There are 2 paragraphs. It’s a 1 minute read. Would you like me to explain each section?
Joint Public Statement from the Crown Prosecution Service and the National Police Chiefs’ Council......Wrong law
Are you still talking about self defence?Joint Public Statement from the Crown Prosecution Service and the National Police Chiefs’ Council......
What if I chase them as they run off? This situation is different as you are no longer acting in self-defence and so the same degree of force may not be reasonable.
Are you incapable of copying and pasting the relevant section that you claim says you may use unreasonable force?You need to consider the circumstances of the situation, the fact that the scaffold bar was not an intended weapon but something to hand given the robbers were likely armed and outnumbered Mottie. Further there is enough case law that prevents Mottie’s actions being judged as anything other than reasonable force to prevent a crime and apprehend suspects of an indictable offence.
Nutcase, you like your own posts written under several different usernames.Another that suffers from confabulation.
The function does not exist to like your own posts.
But if it gives you some sort of comfort, you behave like a dog and lick your own post.
I suspect it would give you more satisfaction than rolling aound on the floor.
No. Are you?Are you still talking about self defence?
Nonsense dummy.Wrong law
titterNo. Are you?
Nonsense dummy.
Do you know what reasonable force is dummy?
The simpler solution to avoid any miscarriage of justice, especially in today's leftist climate, is to avoid calling the police if you managed to get the criminal.You need to consider the circumstances of the situation, the fact that the scaffold bar was not an intended weapon but something to hand given the robbers were likely armed and outnumbered Mottie. Further there is enough case law that prevents Mottie’s actions being judged as anything other than reasonable force to prevent a crime and apprehend suspects of an indictable offence.
