They definitely doI wonder, do MCBs 'fail
I'm not doubting/disputing that - I was asking 'in what way' they fail.They definitely do
Dunno ive never opened one up after the failure, but ive been to many jobs where there's no voltage coming out of the mcb.....its the first thing I check.I'm not doubting/disputing that - I was asking 'in what way' they fail.
Would that be in the vicinity of (probably loose) terminals?Signs of burnt housing mainly
Interesting. As I recently wrote, I would be surprised if the contacts of an MCB which were virtually always closed would suddenly open spontaneously. When you see that, do you think that it may have often occurred as I suggested - inability to re-set after 'deliberate' opening of the contacts (manual or due to overload)?Dunno ive never opened one up after the failure, but ive been to many jobs where there's no voltage coming out of the mcb.....its the first thing I check.
Maybe the toggle doesnt switch it back on, not really sure, next time it happens I'll break it open.Interesting. As I recently wrote, I would be surprised if the contacts of an MCB which were virtually always closed would suddenly open spontaneously. When you see that, do you think that it may have often occurred as I suggested - inability to re-set after 'deliberate' opening of the contacts (manual or due to overload)?
That's what I keep suggesting - that (other than for incidents of over-heating), the 'failures' people are talking about are perhaps failures to be able to reset after a legitimate opening of the contacts (manually or by an over-current trip) - since, as I've said, I find it hard to see how/why a device with almost permanently closed contacts should/could suddenly and spontaneously openMaybe the toggle doesnt switch it back on, not really sure, next time it happens I'll break it open.
Indeed. I imagine we have all seen it - but, as I've said, virtually always manifested as an inability to be re-set after a legitimate opening of contacts (manual or due to over-current), not a sudden spontaneous and inappropriate opening of closed sockets (which seems pretty unlikely)Obviously MCBs do fail.
Indeed so. I'm not sure I've ever seen significant thermal damage in a device which had not been 'abused' and in which the terminations were satisfactory.Yes they also char but in my experience that is when they regularly run above their rated current for long periods or due to poorly tightened terminations.
IFAIC I've known one which 'switched off' and wouldn't reset, it felt mechanically incorrect (can't remember in what way) and was discoloured, it fed only 2 double sockets being used for TV etc customer had been there for only a short time. I guessed the sockets had been used by previous occupants for something very different as I 'saw' no reason for failure.Indeed. I imagine we have all seen it - but, as I've said, virtually always manifested as an inability to be re-set after a legitimate opening of contacts (manual or due to over-current), not a sudden spontaneous and inappropriate opening of closed sockets (which seems pretty unlikely)
