Hi Forum,
Hoping for some confirmation here. I have an Aqualisa shower mix (609 chrome I think). Grundfos STR2 1.5 was replaced 10 months ago, now the pump cuts out when cold water is selected on the mixer. I'm confident this isn't airlocks or cold water feed issues, pump seems good too.
Could this be a faulty mixer cartridge stopping the call for cold water and causing the flow sensor in the pump to turn it off?
I let all the hot water get used up so only cold in the system and the shower continued to work regardless of mixer temp selection. Turned on the boiler to heat the water to tried again and the pump stopped again when cold water was selected.
Thanks for any advice,
Matt
Matt
