I have quite a bit construction dust from cutting tiles and slabs etc on some of my brickwork. Once I’m done I want to clean my brickwork. Is it safe to directly hose down exterior bricks or maybe even pressure wash it?
Avoid a hose as that will saturated the wall. Use a jet wash on low pressure and a distance from the surface.
Use a soap product to lift the dust, rather than it get ingrained. Not a normal detergent or anything chlorine based, but either a specific masonry cleaner or a ph-neutral soap as used for car cleaning.
