Moving stop tap above floorboards, terraced house
1 Feb 2026
In a Victorian terrace, the stop tap is immediately under the floorboards as you enter the house (there is also one in the pavement outside).There's no formal hatch to access it, but the floorboards above have been cut historically so you can prise one up and turn the tap. The local water company replaced the incoming lead pipe just recently, but annoyingly they have reinstalled the stop tap at an awkward angle, so its now a bit of a faff to turn on and off, as well as having to reach below the boards.
In a couple of weeks the floor is being sanded and some laminate flooring in the hall is being removed. The flooring company will be installing one of those recessed doormats which they say will be simple to lift up to access the stop tap. It also means that I have an opportunity to install a tap above the boards, slightly further into the house, as lifting some boards up now isn't doing damage that won't imminently be fixed.
Maybe i'm overthinking things, but I see my options as follows.
1) Do nothing, tolerate the awkward tap placement but it will be easier to get to with the recessed doormat above.
2) Replace the existing awkward tap with a lever style thats easier to use
3) Move the tap (or add another tap) a few meters into the house and get a plumber to move it above the floorboards.
Mainly interested in opinions on option 3. Beyond the hallway, the route of the pipe becomes uncertain and its much harder to access so it couldn't get put in a kitchen cabinet or anything like that. In the hallway there is already a little bit of boxing going up to the fusebox that sticks out, so a stop tap could sit next to it. The plumber says the tap boxed in or have an access panel, but I'm struggling to visualise how that would actually look. They've said you would effectively have to loop the supply pipe up above the boards install the tap and then drop it back below the boards.
I didn't know where the stop tap was for years, but once I did I thought, hang on, when we're on holiday then maybe it would be a good thing to turn the water off etc etc. Perhaps I'm getting a little bit too carried away with how often I need to turn it off and therefore how much of an inconvenience it is in the current location.
Anyway, does anyone have an pictures of how a stop tap in a hallway, set up as my plumber describes, might look? Will it stick out like a sore thumb and just get knocked every time we hoover past it?
If you can still get access to it, maybe fit a surestop switch mechanism?
How often do you need to turn it off? If it is going to be easily accessed then just leave it be.
You could box it it in and fit a small access hatch, I had it like this in a previous property.
Is it a modern one in the pavement outside ?
Its usually easier to just turn off outside
Thanks all.
There is a modern one in the pavement outside, which has recently been renewed so does indeed work. I don't know why I haven't though to just turn that one off, it does feel like it would still be useful to have one in the house. For a long time I was mistakenly told we were on a shared supply, so I think this just doesn't register with me.
The plumber has described that they would propose having a short bit of copper coming up from the floorboards, install the tap, and then have the copper turn back underneath the floorboards. Which I don't actually think would look that bad. Its a solid walled house so although they mentioned an access hatch, I think that would need additional boxing in for an access hatch to then be installed.
Having thought about it, I'm wondering if it is overkill to need it above the floorboards and knowing that the recessed mat should make it easier to access. We had some building work done which meant there were restrictions on the insurance, so I became very careful to turn the water off whilst those restrictions were in place and it has now stayed as a bit of a habit when we're away for more than a night or two. I think the compromise could be to get one of the level ones installed but keep it in the same place.
I would go with option 2, but making sure it was accessible without tools. Unlikely, but in an emergency, needing to turn it off, you don't want to be looking for tools to get to it. Lifting a recessed mat, and an easy access board, would meet that need.
I'm quite torn! Option 2 relies on the the recessed floormat eventually being easy to lift. The guy said it would be, but how they do it depends on the joist location so I won't actually know until they start work. I'm envisaging just a piece of plywood within the mat frame but it would be very annoying if I got a lever installed beforehand, only to find out that the mat will have to be slightly further in to the house and you now can't reach it! Option 3 introduces quite a few more joints in the pipework, and I believe it would need to go from plastic to copper and back to plastic. Its already a real mishmash of different pipe types under there with many different connectors.
Sorry, missed this! I've seen these pop up as a suggestion when I was doing a bit of research. There seem to be many positive comments but then a couple of people said they failed, which put me off a bit.
Water regulations require the stop valve to be in a convenient location. That isn't below the floor unfortunately.
What if it’s “readily” accessible?
In relation to the OP’s situation, it’s apparently “easy” to lift to do your thing.
That doesn't appear in the regs. I don't think you could really argue that below a floor is convenient, especially when there seems to be a simple solution for putting it above floor level.
I mean - in an existing installation, along with an external stopcock outside, I think leaving it how it is with having it easy to isolate can be reasonable.
Imagine trying to find it if you don't know where it is.
Below a removable door mat wouldn't be my first choice. That cannot be convenient.
Then surely the stopcock outside the premises can be used to isolate the supply?
What about the stopcocks that are inside cabinets, behind a blanking plate, in a storeroom filled with junk or even no internal stopcock at all. I know people who struggled to find it when it was in any of those locations.
TBH if it was me, I would’ve probably just add an access hatch. I guess everyone does it differently though.
