I hadn't really been thinking about this from a regulatory perspective. I think if I tried to make everything in this house conform to current regulations I would be in or a very expensive time! I understand the point though - it would be marginally more convenient above the boards.
On thing that springs to mind from a regulations perspective. If the tap was moved, it would pop up from the floorboards adjacent to skirting. Above this particular bit of skirting runs an electrical cable in trunking. Either the tap would be installed onto the skirting, in which case it would be very low to the floor. Or, if the pipe went up above the skirting it would need to cross this trunking at 90 degrees. Is that allowed - would it mean that the copper pipes have to sit further forward from the wall so as not to touch the trunking?
