- Joined
- 22 Jan 2007
- Messages
- 23,668
- Reaction score
- 3,380
- Country
Of course, which isn't compliant.Then surely the stopcock outside the premises can be used to isolate the supply?
I get that below a hatch is ok for some, for me it isn't.
Low to the floor is fine, especially as the pipework is just going back down below the floor anyway.Either the tap would be installed onto the skirting, in which case it would be very low to the floor. Or, if the pipe went up above the skirting it would need to cross
I think if I tried to make everything in this house conform to current regulations I would be in or a very expensive time! I understand the point though - it would be marginally more convenient above the boards.
Lol, access from a recessed doormat. Ok...If it was my house, given that you already have a stopcock outside, and given that you'll have easy access via the recessed doormat, I'd go with option 2.
I'd be tempted to get a doormat with the word 'stopcock' printed on it.Lol, access from a recessed doormat. Ok...
'Welcome' is more usual..I'd be tempted to get a doormat with the word 'stopcock' printed on it.
Only if you are...'Welcome' is more usual..
but denso might just still walk inI'd be tempted to get a doormat with the word 'stopcock' printed on it.
