Gate alarm
With you think these needs a deeper look, doesn’t add up. The relay works via the panel, panel not triggering bell after power cut.
What was cause of power cut?
Power cut caused by high winds, rural end of line
Does the panel have a chime button, at the moment it sounds like the relay is working, the bing bong is not, which is a door chime like thing. That could have been disabled when the panel lost power in the power cut.
Possible nothing broken? Panel would not show any faults for chime being turned off. It would possible show faults if the wiring was wrong, although panel speakers don’t usually show up as a fault if not wired. Normal speaker sounds would still work.
If I open the panel will there be an anti tamper device
