Bosch Dishwasher, all lights on
15 Nov 2005
South
Cook Islands
Presumably it's in pain?
What might it be?
None flashing.
I left it powered off at the wall, but got the same after.
Did the problem arise after a wash cycle, John?
A rudimentary search on google suggests water may have reached the PCB.
You could try holding the start button for 3-5 seconds, while the PCB is on and all lights are illuminated.
Failing that, try having a look at the PCB for any water ingress.
I don't think so
I unpacked it today, put some dirty stuff in, pressed the on button and it lit up. The door had been slightly ajar for airing after Saturday's wash.
The electronics are knackered, time for a new dw.
Had some gremlins in my Indesit dishwasher for years; it would switch on only after pulling the plug out for 5 mins and then if you switched it off, it would never switch on again until the plug was pulled again. Right ballache considering where the plug was (it was easier to turn the entire ring off)
Eventually got around to pulling it apart and found that where the door met the body, the constant flexing of the wire bundle there had broken one of the wires. Soldered up, reinforced and sharp adjacent edges smoothed off and all is now well again .. check for similar in yours?
FD 04/01
I don't think it's very old.
January 2024, is that?
Edit
Yes, it was bought in Feb 2024
It was working after being disconnected overnight.
FD 04/01
Edit
Sadly Bosch are not producing quality products any more.
We replaced our 10 year old one with a Beco and registered it for the 5 year warranty as advised by my local appliance specialist
Needs to be fit for purpose and last a reasonable amount of time . (2015 consumer act .)
No they don’t . Have made many claims at 4-5 years .
Good for you, seriously. That's not what the legislation says though, maybe not worth the manufacturer's time and effort.
