I noticed the tundish is streaming cold water.
I emptied the radiators and opened the hot tap.
I shut off the valves (blue and red ones in the photo)
When I shut off the blue ones the water stops streaming. Either one of them on starts streaming again
The pressure in the expansion valve was empty so I pressurised with a foot pump to 1 bar.
Turned on the valves again and the water kept steaming.
The expansion vessel is factory pre charge 3bar, zilmet 18ltr type 19. The manual only shows the pre charge, I believe the set pressure is according to height.
Could it be likely the expansion vessel needs replacing or just needs to be set to 3bar?
Thank you
Thank you
