Miswired light switch
It is a bit odd that it seems to ne wired in FP200 cable....thats usually used for fire alarms or emergency lighting maybe.
The switch is for two sets of bulbs in the kitchen. There is fire alarm in the hallway outside the kitchen.
You say the earths aren't connected,.maybe connect them to the back box if theres a terminal or put them into a connector block.
Im still not sure why that type of cable has been used.
The back box is plastic and nowhere to connect the earths. The earth conductors are sleeved and not exposed on the cut end. I suppose that's good enough?
They should be in a connector, but it won't make a difference if you leave them as they are.....I assume the sleeving is longer than the wire so they wont touch anything.
[the two earth wires] should be in a connector, but it won't make a difference if you leave them as they are.....
Well, do we know how they are currently?
They must be connected together, somehow.
Are you sure that is the correct diagram this
No. The actual diagram would be a 1 way switch connected to the bulb directly. It wasn't obvious to me at the beginning where the neutral was. I thought it was in the switch.
They are separate in the back box. Since the house builder did that, I can assume that's proper because nothing else is wrong.
