The switch is for two sets of bulbs in the kitchen. There is fire alarm in the hallway outside the kitchen.It is a bit odd that it seems to ne wired in FP200 cable....thats usually used for fire alarms or emergency lighting maybe.
Looks like T&E to me.Im still not sure why that type of cable has been used.
A bit odd but no problem.The switch is for two sets of bulbs in the kitchen. There is fire alarm in the hallway outside the kitchen.
Oh yes maybe, it looked round when I first lookedLooks like T&E to me.
The back box is plastic and nowhere to connect the earths. The earth conductors are sleeved and not exposed on the cut end. I suppose that's good enough?You say the earths aren't connected,.maybe connect them to the back box if theres a terminal or put them into a connector block.
Google says T&E is travel and expenses. I am sure that isn't the meaning hereLooks like T&E to me.
They should be in a connector, but it won't make a difference if you leave them as they are.....I assume the sleeving is longer than the wire so they wont touch anything.The back box is plastic and nowhere to connect the earths. The earth conductors are sleeved and not exposed on the cut end. I suppose that's good enough?
[the two earth wires] should be in a connector, but it won't make a difference if you leave them as they are.....
Wouldn't really matter if they were both separate if they are just 2 earths coming from different lights.Well, do we know how they are currently?
They must be connected together, somehow.
