Tapping into lighting circuit keeps tripping MCB
21 Jun 2026
I am hoping to get some help. I am trying to tap into my lighting circuit for a mirrored cabinet. Havent received the cabinet so just wiring for it now. However, when I connect a wire into one of the live lighting wire in the loft, the mcb stays tripped but when I disconnect the wire for the mirror, I can reset the mcb fine. Its a brand new wir. Is there a reason for this tripping as I cannot figure it out. I've drawn a simple photo. Wires 1 and 2 is the same wire i'm tapping into and 3 is the wire to mirror. 1 photos is of the 3 cables attached and the last is the one hanging for the mirror. I will sleave the earths as this is just to find out what is causing the trip. Help please.
How do yo know that’s a lighting wire in
How Was it before you touched it
It’s not a switch is it
Have you tested the cable at all nothing in the wire shorting out
Is it new wire
What is at the other end have you used a 3 way wag at the end shorting
oh my god, I am so stupid. Not sure how I missed that. Thank you.
Chirist! Not being rude but if you are making mistakes like that and can’t work it out I’d suggest not touching electrics. You’re going to kill yourself!
