- Joined
- 27 Jan 2008
- Messages
- 29,397
- Reaction score
- 3,615
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Basic what I was thinking, well put. If one keeps an eye on the relative humidity then it could be used, but one would still need a heat pump at some times of the year, either self-contained in a machine to tumble the clothes, or as a stand-alone unit to dry the air in the whole room.You're just transferring the water in the clothing to the warm air you have paid to heat...and that water will readily condense on cold surfaces.
It only works whilst the air and building fabric is sufficiently warm and a sufficient air change to transfer the higher humid air outside.
For many this isn't the case and will just lead to damp and mould issues.
Don't get me started on these heated drying racks...
Much depends on other factors which will make the homes' humidity raise, like people, pets, plants, and gas appliances without flues.
