Chimney insulation
6 Oct 2025
Hi, we have a small fireplace in our kitchen an want to plasterboard it up with a small vent. But can anyone advise how to best insulate the chimney space - is it just a case of adding in some rockwool and leave a small bit of space for air to get up and down? Previously we'd had a balloon draught excluder but just keeps slipping down.. thanks
Stick a C Cap on the pot. I'd run a short bit of overflow pipe up the flue and ram rockwool around it. Small vent on the plasterboard.
I almost did the same thing with mine and just filled the chimney space with insulation. Ended up getting 1 Hour Chimney to look at it first because I didn’t want to trap moisture or create another problem behind the wall. They checked the setup and told me what was safe to close off.
