Twin slot shelving shoot-out?
13 Jan 2012
Hi
Has anyone recently compared the various twin slot shelving systems that are easily available?
I'm wanting to put up a fair amount of shelving and was shocked to see that the quality of twin slot uprights readily available from Toolstation/Screwfix has decreased, certainly so that some old Spur brackets will no longer insert when the upright is fixed to the wall.
The uprights' profiles are now made from thinner metal and the profile has reduced to about 12mm thick from about 16mm. I'm not sure how much this affects the load bearing capacity, not least if I have to grind down old brackets to fit. Annoyingly none of the product specifications ever mention the profile thickness so it is left to discover after purchase.
Toolstation stock 'XTrade' - with grooves at the front running along the length and about 12mm thick. Also Rothley (no idea of thickness) but that's delivery only, in upright & bracket packs and £9 collection fee if it's no good.
Screwfix do 'RB UK' (also with grooves at the front running along the length and 12mm thick - though I'm sure it was thicker in the past and without the long grooves and small notches by each slot). Also a cheaper version 'RB UK Antibacterial' (for medical installations?) so I can't imagine that being any better.
B&Q do 'Form Twinny' (apparently 12mm deep) in store.
The original Spur system seems to be mail order only (£19+VAT).
Are the cheaper ones OK if I use more uprights or do I bite the bullet with an online order and hope I get it correct first time? I suppose it's cheaper than Vitsoe 606.
The old Spur shelf brackets never fitted other manufacturers wall brackets , you need the buy all same system. Though if you tap brackets with a hammer when installing you can get them in .
Have used all without any problem, the thinner wall brackets compensate by having more screw positions than Spur .
Screwfix seem to be cheapest option .
Tx for the advice. I found the XTrade uprights had the same number of holes as the old Spur
(off-white) ones but the RB UK ones (two left most uprights) had more.
Also compared are the Spur and RB UK brackets.
The RB UK ones from Screwfix seem to be the right balance of availabilty/price/options so far.
I found that a gentle filing off the mounting points on the brackets would make them smoothly interchangeable.
I stick them on a grinder wheel for a few seconds, though you can just tap them so the rear buries itself in the plaster of the wall , it’s only a couple of millimetres.
I am the inventor of "LesLok" (Google it) which is a simple bracket that sits on top of the shelf and stops it from sliding around. I had to test just about every manufactured product to make sure it fitted and as a lot of you have found they are not always interchangeable. Even in the case of Screwfix who supply RB they do the original and also "antibacterial", they look the same but are not interchangeable, it has caught a lot of people out. Rothley supply a lot and Element32 from Germany are also excellent. Spur was one of the earliest but have rather lost their way. I used to always buy Spur more than 50 years ago but again, it only really fits itself unless you fancy using an angle grinder on the brackets. Another odd one is Swedish "Altro" and that has a completely different slot spacing. Twin slot shelving is brilliant stuff and it takes a great deal of weight. Just don't space the uprights too far apart, it might save a bit of cash but it is remarkable value for money and you will regret it when your shelves sag.
Take a look at leslok.com, a simple solution to at least one small problem.
