Hello,
I'd like to open up my chimney 100mm on each jam and then also 100mm at the back. The chimney is stepped (see photo from underneath the floorboards in the room above the lounge) and lined with terracotta pots. House was built early 90's I believe.
Existing opening width: 570mm
Proposed opening width: 800mm (less lime render)
The existing lintel is too short, so instead of 900mm x140mm x 65mm, I believe I need a 1100 x 140 x 65 which will allow 150mm bedding each side. The breast is 1255mm wide.
I'm struggling to understand how the forces are distributed in my chimney breast, so my first question is... do I need 0, 1 or 2 acrows/strongboys to safely replace the existing lintel and if so... how far above the lintel should they be placed?
The other issue is the gather that supports the clay flue seems to be sitting on the back row of bricks I want to remove to increase the depth of the opening, but as far as I can tell they are supported from the bricks underneath and not tied into the jams. If this is the case... is it supporting the lower section of terracotta flues or is it structural? So will inserting 2 x 304 steel (50mm x 100mm x 450mm) flat bars stitched from the front to back, be enough to support the liner/gather so I can safely remove the back 100mm of bricks?
All opinions/advice welcome!
Thanks.
Thanks.
