Plumbing waste fall query
15 Jan 2025
France
Hi guys,
I'm installing a shower with 40mm waste pipe in room above the photo. The pipe will come down from room above where the red dot is. I'm looking to attach the waste to where you see the washing machine waste as this is my only access to a nearby waste. My question is does the fall have to be very gradual all along the walls or can I do gradual on one wall and vertical drop to attach to the waste on the other? I'm not bothered about hiding this waste pipe as its all in a utility room. Thanks!!
Fred
Waste descends vertically by 25 mm for every 1m
Yes. You can have a vertical drop and then run the pipe with a gradual fall to the existing waste. It doesn’t need to slope continuously around the whole room. Just ensure the horizontal section has a continuous fall toward the drain and no drift hunters low spots.
