Just changed the dipped bulbs on my 2004 Honda Civic with ease and now considered checking the beam alignment with a view to adjustment.
On initial examination I could not find any form of mechanism for adjustment.
On close examination I found the U shaped arrows marked R - L on the plastic rim running along the top of the headlamp. This was in front of a hole which guides a screwdriver (at 45 degrees) to the white toothed gear.
So far so good!but I'm more interested in the vertical adjustment
I then found another U shaped mark with arrows U - D more in the centre position, but no hole and nothing in the form of adjustment below/behind.
This mark was directly in front of the screw securing the light strap to the bodywork. I also noticed the plastic strap had a pointer moulded on one side and the bodywork had 5 serations.
With the screw removed the lamp was still firm, but I noticed another plastic strap running up the drain channel on the wing.
This was partially hidden but revealed another securing screw.
Again with this screw removed the lamp was still firm.
I'm now thinking! The markings cater for adjustment so perhaps the mechanism is at the base of the headlight but I can't see anything.
Does anyone know if there is a mechanism and how to access it?[/b]
