1 inch compression nut
Status
Not open for further replies.
8 Jun 2011
Essex
Do 1 inch compression nuts exist?
I've looked on BES and everywhere I can think of...
metric know 22mm
1" is now 22mm. You learn something new every day.
28mm is the nearest metric equivalent to 1", and 28mm compression fittings are available.
IIRC a lot of Imperial compression fittings used British Standard Brass threads, which were very similar to metric fine threads, but metric fittings tend to use much coarser BSP threads.
I believe 1" pipe can be fitted straight into 28mm fittings without any problems.
OK, Thanks.
Would a 28mm compression fitting be too big for 25mm blue MDPE pipe?
If so, would a 25mm copper olive on the MDPE help at all?
OK, Thanks.
hang on, are you talking about MDPE fittings, or converting from MDPE to copper / plastic ? If it's for either, then there are MDPE fittings that are available for this purpose.
The only compression end to use BSP thread for the capnut/fitting body is 15mm. It is 1/2" BSP. All other sizes are "*******" threads.
Status
