- Joined
- 27 Jan 2008
- Messages
- 27,661
- Reaction score
- 3,347
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Looking at Steve and RF Lighting post over energy used to power down lights has got me thinking and I did not want to confuse xspurt (Is that a drip under pressure!).
So if we compare 12 volt and 230 volt small spot lights each seems to have a few advantages.
In theory when powering 12 volt units from an inverter it should be able to correct any voltage fluctuations and give a constant voltage. But this would only be true with inverters and with transformers there would be no advantage. Also with inverters if they were designed to correct any voltage fluctuations then they would not work with dimmer units and many do.
Maybe the inverters can read the difference between a chopped supply and a low peak voltage but I am not convinced!
Also I know with many positive and negative chopping and post and pre peak chopping of wave form need to be matched so it is hard to fit dimming units latter because one needs to find matching dimmer.
Yes I know you should never dim quartz lights as they will have much reduced life but never the less many people do fit them.
Unlike the 230 volt version both dichroic fit into same holder and also there is a problem with overload where 50W lamps can be fitted into systems only designed for 10W and either this will cause the inverter/transformer to shut down or burn out.
However the GZ10 and GU10 are not perfect either being reliant on correct voltage and there seems to be loads of low quality units on the market which means they need changing far too often.
They do however have a better electrical connection.
Both extra low and low voltage have LED versions but with extra low voltage some of the inverters will not allow them to be used as below min volts and with low voltage (230) they tend to be longer and stick out of the holder.
Cold cathode or florescent versions seem to be limited to the 230 volt version again physical longer.
The quartz halogen because of the hotter light and reflector in theory they are suppose to be more energy efficient than normal bulb. This of course relies on correct fitment and replacement. With angles of 10°, 24°, 36°, 60° and wattages from 10 to 75 even if originally selected with care once a few bulbs have been replaced it is unlikely to still be set up correctly.
With all these, variation I still cannot see how anyone with hand on heart can say using a transformer and extra low voltage lamps with loses can be better than the 230-volt low voltage lamps.
However where we need low voltage because of safety then of course the 12 volt SELV lamps have a distinct advantage. Also because some low voltage inverters/transformers will auto shut down if the bulb is too big where heat is a problem they also have some advantages but this is not so good as there is no SELV equivalent of the selective properties of the GZ10 and GU10 where dichroic lamps will to physical fit the GU10 holders.
If we were to take a single make of both lamps I am sure we could show some advantages with the SELV 12 volt versions but once fitted the chances of only a like for like replacement is slim. The same goes for the Low voltage 230 volt versions I have heard many complain about how quickly the lamps blow but when you inquire they bought the cheapest of cheap replacements and don’t seem to understand why a £5 lamp lasts longer than a £1 for 3 lamp. Yes I know not 15 times longer but to replace every couple of weeks is a pain but once every 6 months is acceptable.
There will be the odd premises who suffer from over voltage and need good quality inverters to smooth out these and as a result will find 12 volt lighting better and also bathrooms where 12 volt lighting must be an advantage but in the main I see no real advantage in using a 12 volt system.
So gauntlet is down show me I am wrong.
