The fees are the same as for a Building Notice submission.
Risk:Ban all sheds. Doing the work under a building notice has worked for me on at least three occasions. It is not risky, it is not lunacy provided that you follow the iee onsite guide and have some common sense.
Finite, because if you don't tell LABC how you will comply with P1, and they decide, for whatever reason, that they don't like what you did, you'll have problems.
Reward: ZERO.
I am truly and genuinely gobsmacked, (and TBH, a tad horrified) at the number of people here who have no idea what the term "full plans submission" actually means.Reward: No need to draw up complete plans for a simple job which doesn't really need all the trouble and time taken to draw up a full set of plans.
To save me looking, for electrical works does a Building Notice save you money?Checking the current fees for my local authority, I came upon this item which says that in some cases they are now charging more for a building notice than for the combined plan & inspection fees:
http://www.northnorfolk.org/planning/241.asp
(Doesn't apply to purely electrical works.)
It does not mean that you have to do drawings.
But in this case the plan is "To run around 15m of cable (10mm or would 16mmbe better ?) from the heater to the consumer unit, put in a mcb (50A or 63A ?), pinning the cabling to the wall in the cellar."
They're amenable to being asked things like that.Somewhere in the documentation my local council states that detailed drawings are required with a full plans submission. But maybe they don't really mean that when it comes to minor electrical works.
Then maybe you should have planned it betterWhat if after starting the job you realize that there's a snag with that plan, and you need to revise it by choosing a different cable route, say increasing the length by 50% which necessitates use of a larger cable?
Then maybe you should have planned it better![]()
My council was happy with "Electrical installation work in connection with the extension of a domestic dwelling."
as BCOs are (probably) not qualified to judge the correctness f those.
