Hi All,
My mate got me to have a look at his bathroom downlighters tht was working for the first few seconds after turned on, but would then go out. I pulled out the bulb and holder and could see what I assumed was a transfomer through the whole. It had Aorora 50 W 12V written on t, so after a post on here I bought a new one - assuming that each downlighter had its own transformer.
Over the weekend I finally got around to trying to install the new part, but when I removed the entire light assembly to access wiring I saw that what I had been looking at was not a transformer at all! It was just an L shaped bracked witha connecting block in it. Two wires (both black) going into one side of bloack, and two wires from other side to bulb.
So I'm a bit confused!
I assume this means that each downlighter does NOT have its own transformer, but whats with the L shaped bracket? The connecting block does look as if there has been some heat there . . . should I just replace the connecting block and hope for the best?
thanks for any ideas!
Huey
Huey
