I know that regular 12V halogens are ok on DC ( as I have one in my van and my cousin installed several for his campervan ), but do the newer LED equivalents work ok on DC?
( not technically correct, they will work on AC but only on one half cycle.. ),
LED,21 MR16 GX5.3 12 Volt LED lamp seen here has built-in voltage regulator - safe up to 15v but many will not work on DC.
For battery driven LEDs a common and perfectly safe "trick" to make them look brighter is to pulse the LED with 5 times normal current many times a second. If it is ON for 10% of the time and OFF for 90% the average current is half that that would be taken if it was ON permanently at its normal current. But the eye sees the 5 times normal brightness and persistance of vision makes the LED look 5 times brighter when only using half the power.
