12v MR16 downlights
3 Jun 2019
Totally fed up with this rubbish - keep blowing/overheating wires. I have three in the kitchen, each fed off its own transformer/driver. I want to rid myself of these and replace with some low profile bulkhead 14w LED lights. Is it as simple as removing the driver and feeding into the new light?
Thanks for your speedy reply, much appreciated. It does look like mains lighting cable feeding into the driver, but there is a lot of lagging there. Can't get to the floor above (it's a flat), and no other access in the ceiling to follow the cable back, without cutting a piece of plasterboard away. Without the aid of a tester, if I remove the driver, and wired up the low profile 240v led fitting, I assume if there was some other transformer in place, the worst case scenario is that the lamp wouldn't work??
