Adding a new rad. and to potentially avoid lifting most of a living room hardwood floor + boards I think that I can feed the new 15mm pipes the 5 metres they need to go. Will be going parallel to the joists, so no worries about hitting anything solid - the only (hopefully
) tricky bit will be feeding pipe along the gap of about 6 inches between the deadening and the bottom of the floorboards.
Looking to use the JG Speedfit layflat - is it quite easy to feed?
(I have some speedfit already but not layflat and off the coil it retains too much shape, so would be impossible to use - hence the reason for hoping layflat is the answer
