I'm planning to replace an existing radiator this weekend; a single with a double and I'm aware the pipe centres from the will will need to be increased from around 20mm to 55mm to accommodate the depth of the new radiator. The floor comprises large chipboard boards with oak flooring on top, meaning it is very difficult to change the position of the pipework, or even allow more movement in the existing pipes. I therefore expect to have to cut the existing pipes down and to attach an offset pipe bend to reach the new radiator tails.
I will need to purchase a pipe bender and have found what appears to be a good one at Screwfix: Monument Tools Lever Copper Pipe Bender 15m
Having viewed a few videos I have a concern that it would be possible to create two bends in a short piece of 15mm copper pipe that would provide the additional 35mm reach as I believe there is a limit to the radius that can be achieved. I can obviously fit the new radiator higher up the wall than the existing one, to allow a longer pipe to be used, if this is necessary to achieve the new connections.
Is this likely to be possible for the additional 35mm reach that is required?
I would appreciate any advice on doing this as it will be my first attempt to use a pipe bender. I imagine I may go through a number of lengths of copper pipe before I get the bends right!
