15mm plastic pipe to 15mm copper using compression
25 Jan 2004
I am changing about some pipework and would like to cut a 15mm plastic pipe and reroute it by using a straight 15mm compression fitting onto 15mm copper.
Now, I have seen elsewhere on this installation that the same pipe is fitted into a 15mm compression fitting. If I wish to do this do I need a special insert into the plastic pipe to keep it from getting squashed?
Use a speedfit connector (pushfit). And don't forget to maintain your earth bonding.
I know speedfit is probably easier, but I am just wondering how it is done with brass compression fittings. I don't fancy taking apart the one compression to plastic connection in the installation just to take a look!
How is it done?
Or any other type of fitting for that matter as well. Otherwise well lets just say you'll be sorry!!!
Alan
