Just completed on an 1893 terraced Victorian. It's pretty obvious that it's been treated in a bit too modern of a fashion in past years, and I've been setting out to fix that. It has an extension on the back.
One of my long-term dilemmas - the rear render. (There's render on the front too, which sounds hollow, but I somewhat suspect it's an intentional cavity as it is hollow across the entire face. I have other problems there.)
At some point, the entire rear building was pebbledashed. Certain areas of this have blown in the past, and recent owners have patched with a cement based pebbledash. In places, and poorly. Since then, more sections have blown.
The blown render was forcing water ingress. I've hacked off the worst of it, so that water doesn't pool against the brick for the current time, but I'm not sure of my next steps this close to winter, when my money is tied up in more critical repairs. Any help would be appreciated:
View media item 66100
- I don't know if the original render (or current pointings, for that matter) are lime or cement. The new stuff is obvious - how to tell with the old stuff?
- Is it safe to leave on over the winter until I can effect repairs, given blown spots? I'm not about to put a weatherproofer on Victorian brick, and the brick underneath looks reasonably ok.
- When I do repair it, is it better to hack it *all* off, patch, or only hack off the parts on the main building? There are shoddy render repairs on the extension as well, but I can't help but assume that the brick and materials on the extension are much more modern than the main building and are not suited for lime render.
- Is there anything I should do to protect the building for the winter?
- The render goes down to the ground. I've not seen evidence of an integral DPC or internal damp above ground, but am I right that this should be addressed?
