Hello could anyone give me some advice about my kitchen/downstairs loo floor?
Our house was built in 1946 and is the kind of semi that has a single story extension at the side. We think that originally this may have been a coal store, downstairs loo and possibly a scullery/kitchen. At some point it has been knocked through into one larger space with a little lobby to keep the new kitchen and loo separate. It doesn't appear to have cavity walls - going on the depth of the window sills, and we are not sure whether it has been dry-lined.
Ok here's the problem...
The floor in the loo is very wet where it joins the outside back wall and not quite so bad along the outside side wall. The skirting is wet and begining to rot. There don't appear to be any leaks from the loo itself, though we found a problem with a broken drain about two feet from the sidewall - must have been leaking for ages but now sorted. The internal floor of the loo and kitchen is below the level of the dpc, and we think this may be part of the problem. We appreciate that there may be a large moisture resevoir at the base of the side wall from the old leak, but most of the wet is at the back wall/floor.
Is there any way to combat this without raising the floor level?
Would French drains help? The oustside ground level is pretty much the same as the internal floor and we intend to lower this at the same time as digging the French drains. Would tanking the floor and walls up to the DPC help?
If we must raise the floor what's the best way to go about it?
Sorry to ramble on so much If you have stuck with me this far your patience is very much appreciated.
Louise
Louise
