I wouldn't consider caps to be satisfactory. They are merely aesthetic and can be removed or fall out. Nylon screws are OK (but expensive) but still do not meet the requirements of BS7671 for a cpc to be run to and terminated at each point of wiring.
You know as well as I do that you can minimise the risks by fitting accessories and luminaries that do not require an earth connection then install a notice at the consumer unit position.
The current requirements are to have a cpc at every point.
It's not relevant whether it was a requirement in 1958. And I made my point why I consider screw caps to be unsatisfactory. Also no such warning notice is prescribed by BS7671.
