- Joined
- 11 May 2005
- Messages
- 1
- Reaction score
- 0
- Country
Hi all, Sorry if this has been done to death but..
I have a 2 way light set up as per the "standard setup" in the for reference section and obviously it is easy to extrapolate this out to provide 2 gang 2 way switching. All my lights are wired loop-in from the master switch point to each light in turn, terminating at the last light. (One light run for each gang). 3- core between the switches, no problem there. Question is, where do I wire the main T&E from the CU into the 1st gang on the master switch (assumed live to L1 and Neutral to L2 ?) and how do I get a feed from the 1st gang to the 2nd gang ?
