2 GANG SWITCH
25 Aug 2006
West Glamorgan
I HAVE A 2GANG SWITCH.3 SETS OF WIRES COMING IN, 1.POWER SOURCE GRN/YEL BLUE BROWN.
2.GRN/YEL BLUE BROWN.TO OUTSIDE LIGHT.
3.GRN/YEL BLUE BROWN.TO INSIDE LIGHT.
THE SWITCH HAS 2COMS SL1 SL2 THE GRN/YEL IS OK BUT WHERE DOES THE REST GO?PLEASE HELP :
First of all, press here:
You need to connect all the earths together in the terminal in the back box, and if the switch is metal you need to take an earth to the switch plate too.
Put all the neutrals into a connector (the blue wires)
Put the feed live (brown in cable 1) into one of the common terminals, and then use a short piece of brown wire to link the two commons together.
Connect the switched live for the outside light (brown in cable 2) to SL1
Connect the switched live for the inside light (brown in cable 3) to SL2
