Incorrect.
Why? I have done it in the past. If two items are closely associated in type, and always physically close to each other, and low wattage, and can be easily and safely accommodated, then fine.
Incorrect.
Agreed, as long as the wiring was properly secured in the plugs terminals and the cable grip was adequate, I wouldn't fail it on a PAT.Whilst it might seem a bit off at first thought, assuming everything was done correctly what really would be the problem with having two cables in one plug?
Well, it worked for me. Also, at my old workshop, I had an outside socket. So that it wasn’t permanently on for others to possibly use, I connected it to another socket on the inside using a piece of 2.5 twin and earth cable. Again, it worked for me.![]()
I clearly disputed the claim that "it shouldn't be a problem." It categorically is a problem.Why do you dispute that Mottie has wired 2 cables to a plug?
As above.How can he possibly be incorrect in telling us what he has done?
By definition it can't have been done correctly, as it is incorrect.Whilst it might seem a bit off at first thought, assuming everything was done correctly what really would be the problem with having two cables in one plug?
It is impermissible.Why? I have done it in the past. If two items are closely associated in type, and always physically close to each other, and low wattage, and can be easily and safely accommodated, then fine.
Then you shouldn't be carrying out In-service Inspection and Testing of Electrical Equipment.Agreed, as long as the wiring was properly secured in the plugs terminals and the cable grip was adequate, I wouldn't fail it on a PAT.
And I don't believe I have seen any PAT guidance that has suggested otherwise?
Is it permitted by BS 1363?Please do explain, what might be wrong with two items, wired into one plug?
It is impermissible to terminate 2 wires into one terminations?It is impermissible.
