All,
I have an existing 2 pipe system which I installed in detached garage 16 yrs ago.28 mm pipe to manifolds and then to the rads,with new Danfoss control system(brilliant).
Question.
I have built an office which is on the unused pipe side of the boiler,and I propose to pipe from these outlets to a single rad.Anybody have any theories on whether I should run with 28mm then to micro bore ,or 28mm down to 12mm with or without a pump.If I run without a pump will the existing 2 pipe system be robbed of heat.The system is on same level i.e. a bungalow.
Ta.
Question.
Ta.
