Sounds strange that two sockets are down on a RFC.
Are the sockets close to each other?
Are the sockets actually spurs?
Could be a loose connection in the first spurred socket or the socket the spur was taken.
Is the circuit not a RFC but a radial. If a radial check for loose connection at first faulty socket and the one that feeds it.
Are the sockets on a separate circuit and not part of the RFC or fused spurs.
if so follow sparkwrights directions
Check all switches and fuses at mains position.
Perhaps a fused spur unit situated somewhere served these sockets. If there is one check fuse and if switched check switch is on.
Thanks, I know the sockets are on the ring circuit because I watched it being wired up. no fused switches that could account for a failure.
all sockets have been checked of overload i.e tell tale brown signs - none.
everything was working fine until last Thursday. No DIY that I am aware of.
We know it is a ring main. the sockets are at opp ends of the room and the spur is in the hallway.
Have checked all sockets for loose wires - can't find any
Don't assume it's a RFC, because you saw it wired up.
Lets have some evidence of this.
What size MCB/RCBO is protecting the circuit?
What size cable are the MCB/RCBO protecting?
What number of conductors are terminated in to the MCB/RCBO?
Do you have any testing equipment, such as multimeter?
