2 Spurs
7 Oct 2004
I am replacing my current free standing cooker with an intergrated hob and oven. The cooker is on a dedicated circuit with 45A fuse, I was planning to wire the exisiting cable into the 5.8kw hob and replace the 45A fuse with a new 32A MCB:
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A331832&ts=93154&id=87979
For the oven I was going to spur off a nearby ring main socket and then into a 20A DP switch http://www.screwfix.com/app/sfd/cat/pro.jsp?id=66137&ts=90628
Which then fed the oven under the worktop into a unswitched 13A socket
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=45445&ts=90696
Can you confirm this is ok and also the other problem is, I have a chimmey hood that needs power where is best to wire this into. As I cant create 2 spurs from the socket or can I?
Thanks.
Your plans sound fine. Though there are more attractive 20A switches around.
An alternative is to wire a single socket in the same way as the hob. Using a cooker outlet plate, with 2 output wires, one to the hob, one to a socket next to the outlet. Plug the oven in here. Then you only have one switch for the hob and oven. (If the cooker is wired in 10mm² (as it should have been with a 45A fuse), use 6mm² for the few inches to the socket, it will be easier to terminate)
And spur off the local socket you mentioned for the extractor. Just use a fused spur next to the cooker.
Haha! i happen to know :lol: his cooker circuit is in 6mm and I have advised on the other thread to use a 30A or 32A MCB; which will be just enough to feed the electric hob from the CCU :wink: leaving the oven to feed from a socket on the ring.
must people create multiple threads about the same subject??
and WTF was his old cooker circuit doing on a 45A fuse? :shock:
Sorry to post what seems like multiple threads but I am all ok with the oven side of things now.
Would this switch do the job? http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A431906&ts=72255&id=13014
Its just the chimmey hood I need advice on. As I am am using the nearby ring main socket to feed the oven where or how is best to supply the hood??
I take it I cant supply both the oven and hood off this one socket.
I promise guys that I will try to leave you alone if I can just just this part sorted?
Cheers.
Any help would be much appreciated.
Thankyou
(This is my current cable which will feed the hob, It is 6mm isnt it?)
Sorry I was just thinking. Regarding my last post is it feasaible to fuse the spur for the oven down to 13A thro' an FCU . then I can add the chimmley to this?
