- Joined
- 11 Mar 2015
- Messages
- 5
- Reaction score
- 0
- Country
Hello,
I bought this strimmer second hand off ebay last year. When I picked it up, the bloke got me to start it to show me that it worked and it started first time. I then started it again when I got home, refuelled it and then used it twice on our allotment with no problem.
http://www.einhelltools.co.uk/product-list.php?pg1-cid2044.html
Since then it will no longer start. At first it would take a real effort to get going, it would start but then stall immediately especially if you closed the choke. I found that if I got it started and grabbed the throttle straight away I could keep it going but it sounded very loud and would stall again if the throttle was released.
I've tested and replaced the spark plug, that works and the air filter is clear.
So, on the assumption that it was the fuel supply, I tried readjusting the carburettor but no joy. I then took the carburettor off, dismantled it and found that a small rubber bung that sat above the primer bulb had perished and fallen off. Thinking that I had found the problem, I bought a new primer bulb (it came with the bung) and before putting the carburettor back together, I spray cleaned it and made sure nothing was blocked.
http://www.einhelltools.co.uk/product-info.php?pid37021.html (Primer Bulb, the bung I’m talking about is the red ring in the picture)
http://www.einhelltools.co.uk/product-info.php?pid42589.html (Carburettor, FYI)
Now that the strimmer is back together, it still wont start. It may be that the carburettor is not set properly but I've long lost the original position and as I can’t start it, I've no idea how to adjust it.
Any ideas please?
Any ideas please?
