Hi everyone,
Since I moved in there has always been 1 radiator in a spare room upstairs that has never worked. Its competely stone cold and the pipes are cold too. I've lived with that since its only a spare room but now another radiator in the main bedroom has started to do exactly the same thing. It never heats up and both pipes are cold. The rest of the radiators in the house work perfectly. Is it more likely to be an air lock that is causing the problem or a sludge blockage???
So far to rectify the problem I have (in order)...
- Bled all the radiators
- Tried switching off all the working radiators to increase pressure to the non working radiators and hopefully flush through blockage/air lock??
- Added some Sentinel X400 Sludge Remover into the F&E tank in the loft
- Drained off some water from the central heating to ensure that the X400 has entered the heating circuit
- Again switched off all the working radiators to increase pressure and flow of X400 to the non working radiators
- Finally the last thing I've tried is bleeding the circulating pump, this has a bolt right in the middle which I've loosen but nothing seemed to come out (air or water). I switched off the heating before I did this so the pump wasn't on.
I had high hopes for the X400, its been in the system for over 3 days now but hasn't shifted the blockage. Any sugestions on what I can do next would be grately appreciated + whats going on with my pump???
Thank you in advance. PS: I'm not that brave in the DIY department, especially when waters involved!!!!
