I am trying to replace one 2-way light switch with a new 2-way dimmer, preferably at the remote end of the circuit. The 1st attempt caused the dimmer to fail possibly due to 300W load on a 250W dimmer? The 2nd attempt with a 400W version still failed and apparently blew the dimmer again. The instructions only show the dimmer installed with the supply feed L1+L2 and not just remotely connected at the 3-core+E end?
Is this normally the case?
Why are the dimmers failing, are they that sensitive?
