Ok so I got a bit ahead of myself
I am changing the fronts on 2x 2 way light switches.
Having taken apart the first light switch there was a piece of red wire between the 2 sides, but I am now unsure which points it came from.
Plus for one side there is one in (the double end) and then one out at the other and on the other side 2 in at the double end and none out. is this where the extra piece of cable comes in?
Also the previous fronts were plastic and the earth connects to a screw inside the wall - however the new ones are metal - does that mean I have to reconnect to the box itself?
Any advice really would be helpful - and how dangerous is it to test if I am unsure that it is all correctly wired?
