All,
I have 2 lights, both of which need to be under 2-way control. I am looping in at the switches where there is therefore always a line and neutral available.
I am proposing this arrangement:
[code:1]
SWITCH BOX 1 SWITCH BOX 2
----------L---------o---------------------------o-------L----------
----------N---------o---------------------------o--------N----------
o------------N
LAMP1 /o-------------------------o
o-------SL-----o o---L
o-------------------------o/
N----------N------o
/o-------------------------o LAMP2
L--o o--------------SL------o
[/code:1]
(Inside the switch boxes, all L's, N's and CPC's are connected together (not to each other!).)
Between the 2 switch plates (and disregarding CPCs), I therefore need line and netural, plus 2 switched lines for each lamp (6 conductors).
Question is: I can use 3 runs of T & E or 2 runs of 3-core and earth. But with the latter, the SL's for one lamp will be carried in different cables - one with the lighting circuit's L & N, and the other with the other lamp's SL's. With correct sleeving, is this perfectly acceptable, OK, but asking for confusion, or just bang out of order?
I am aware that there are various other arragments of wiring this, but this is one of the more economical in terms of cable.
Thanks in advance - what do you think?
[code:1]
o------------N
N----------N------o
[/code:1]
