I've posted another topic on this in the past, but it went a little off course.
I'll try to keep it brief.
Loft space (where the cylinder will go) is 1200mm max. This means i'll have to go horizontal cylinder or 2 smaller ones.
If I go 2 x 180l cylinders, its still cheaper than a horizontal 300l. Recovery time will also be much quicker.
I plan to have a double bath, and large shower. Bath capacity is 400l. Shower head 450mm square.
However I'm worried about balancing the flow from the 2 cylinders.
Also, if I store water at say 70 degree's. How much usable water do you get out of a 180l cylinder? I'm assume after 90l the water will be down to 50 degree's approx. So after 130l (260 total) the water temp would be too cold to shower.
I'm going to run a combi for the taps. So I could have the stored hot water temp at the very max.
I looked at the RM Stelflow brand. I'm going to call them tomorrow.
